Hi everyone,
I was riding back from work today along the A1. It was really windy and quite difficult to hear exactly what the bike was doing. I had hit near 100 mph and about 10,000 rpm(which is about as fast as itll go as its restricted to 33bhp) and then slowed down again. I accelerated again afterwards from about 70mph (7000 rpm ish) and I only saw the revs go up to about 9000 but the speed did not go above 70? This happened the whole way back? I couldn't get the speedo to go above 70 mph but it felt like I was going a lot faster and the revs were rising! I kind of remember seeing the speedo "bounce" between 65 and 75 at one point when I was decelerating? Don't know what went on there? Has anyone had this problem before? Thanks
James
Speedo?
- My Bike: zxr400 l9
Speedo cable screws into left hand side of clocks, look for black cable with silver attachement.
Tracks down inside nose cone, down left fork leg, into sender unit between left fork leg and front wheel spindle.
Check cable ends are clean and square slightly rounded off on ends, that none of the cable is tatty or broken.
Cable can be picked up on Ebay cheaply.
Rob.
Rob.
Been there, seen it, done it...... back to a 400
