H1 forks: damping adjusters
- OzzyDave
- My Bike: ZXR400H1, CBR929RR
The H manual downloaded from Zxr world shows different damping adjusters to those fitted on my grey import. Does anyone have any info on H1 forks and suspension settings? I've had the rear shock rebuilt and the seals were done on the forks before I bought it but the front end feels odd and seems to drift wide in hard cornering. Any help welcomed.
Shiny side up, mostly.
Re: H1 forks: damping adjusters
Damping adjusters
Some models had pre-load on the top so you could dial them in for your weight.
The tops of the forks should stick out from the top bridge so that only the fork tube is being clamped - check this setting.
