I have read a few threads in here of folks using a ZX6 shock but with no year/model info , pic's or fitting instructions.
The OEM unit can be overhauled - I have two that both need the rod's re-chromed and total cost will run at around £70 a shock (new seals,bushes,oil , bottom damper and gas too).
I currently have a GPz900R Ohlins rear shock mounted up - fully remote
Braided line for remote gas is shorter than the ZXR one so it needs to find a new home, pre-load adjuster has plenty so can be mounted up no worries.
I also have a ZZR400 Ohlins with remote reservoir and it requires a 4mm spacer each side of the lower mounting and again using the ZZR400 lower bolt (Photo's to follow).
