SP fork cartridge swap?
Anyone swapped cartridges? Was re-reading the magazine piece on the RMKD bike and noticed they had put GSXR cartridges in theirs. Anyone put in Ohlins carts or the like? I'm due to have the forks serviced and thought I might upgrade them while they're off the bike.
- Ballsout Racing
Re: SP fork cartridge swap?
I know of someone who has. Steve Jordan of http://www.stevejordanmotorcycles.co.uk/ Motorcycles did it for him
Ballsout Racing wrote:I know of someone who has. Steve Jordan of http://www.stevejordanmotorcycles.co.uk/ Motorcycles did it for him
What did he do, GSXR, Ohlins?
- My Bike: L1 racer
I was looking at some srad gsxr forks and externally they look very very similar.
Maybe they were near enough a straight swap?
I wondered if none sp forks could be made 'sp' just by inserting a cartridge fork and drilling the fork leg to fit the compression adjuster
- Ballsout Racing
Ohlins. IIRC it required some machining to get them to fit.AFM327 wrote:Ballsout Racing wrote:I know of someone who has. Steve Jordan of http://www.stevejordanmotorcycles.co.uk/ Motorcycles did it for him
edit: Actually, they were standard, not SP forks; but I guess it would be the same?
I've got a couple sets of gsxr cartridges I'm going to try out. Let you all know how it works out.
- mick41zxr
- My Bike: ZXR400sp
SP cartridges are same as standard. GSXR cartridges are a big improvement in the rebound circuit & relatively easy to fit, need to be shortened 10mm. Have done these & a couple of 25mm kits into ZXR's. A bit of thought anything can be made to fit.
Regards MB
Regards MB
- My Bike: kawasaki zxr400
can you tell me what year and model gsxr cartridges you can use,i have a set of zxr400 sp forks and one wont damp,so would like to try them,thanks,ianmick41zxr wrote:SP cartridges are same as standard. GSXR cartridges are a big improvement in the rebound circuit & relatively easy to fit, need to be shortened 10mm. Have done these & a couple of 25mm kits into ZXR's. A bit of thought anything can be made to fit.
Regards MB
- mick41zxr
- My Bike: ZXR400sp
1996-2001 these have a 12mm damper rod, so when you shorten them take the tops down to fit the zxr fork caps.
The larger damping rod pushes more fluid through the cartridge & rebound needle is in the rebound valve mounting boss not the cap, so a big improvement over the zxr cartridge.
Regards,
MB
Regards,
MB
thanks for the reply MB,Ian
