I am experiencing a strange problem with some LED indicators and hope some of you may know the answer. I have replaced all four standard indicators with the new ones and put in a new relay to sort the flash rate which it does fine but when i signal left or right all four lights come on!
When i put two standard ones back on with two LED ones, the right and left works as normal
Is this something to do with the current load or resistance? Im not to clued up when it comes to electrics so i need some advice.
Thanks in advance.
