just changed the CAM chain and tensioner on my 1990 H and now have intermittent spark! Can anyone give me the expected reading in Ohms for the pick up. Oh and any other suggestions would be great!!
Chris
pick up output
cbr chris
pick up output
Chris
tomzxr400
Re: pick up output
did you tighten the pick up coil allen bolt on the crank? the readings are in the h manual for what the resistance should be and all the tests to check it other than that check coils , ht leads are secure (very common fault) and test ic unit.
cbr chris
Re: pick up output
Cheers Tom,
Gap on pick up was about 8ft too much!!! Running sweet now so can race this weekend!!
Chris
