Sounds like the relays buggard! :O
I've got a shed load of spares so I changed it with another that doesn't seem to 'tick' i'll see if that makes a difference.. it has a chance
Anyone else had a ticking junction box?
Good thought Rob , also try the relay !RedexRobB wrote:thought about the fuel pump?
Fuel pump relay? I've got a spare one tooMori Man wrote:Good thought Rob , also try the relay !RedexRobB wrote:thought about the fuel pump?
tk400 wrote:I actually have some of the zx6 ones waiting for my engine. They fit nice. The advantage is not actually the voltage. Its to do with dwell time and heat. If you run them on waste spark, there is little difference. If you run them sequentialy then as the coil only has to fire half as much it has a larger available dwell time up high rpm's. As at high rpm the available window for dwell is less that optimal. It is a great conversion , but to take best advantage it is best to run sequentially. I am working on a sequencer to alloy this on the 400. As for these if you just need to make sure the dwell is not to long at low revs as they will over heat. and that the dwell is long enough up high. this can be checked on the CRO. Mine are mitsubishi units. If they are the same I will test them for you on the ignition test rig and give you the data results. you may wish to direct some air over them to help cool them just incase they are a little high on dwell.........the reason dwell is a problem is that an inductor (coil) is the inverse principle of a capacitor. therefore the current increases exponentially and at ful charge it just keeps flowing untill turned off. hence to long a dwell time will overheat them. if this is the case you can add a series high watt resistor of the correct value. But this increases the required dwell time up high. Anyway enough rambling I will check for you. As those coils are expensive and I would hate to see them burn out. nice mod anyway..
cheers
regards TK400
Ok cool that makes sense to me!zimm wrote:could be a dwell issue with the coil's in combination with the stock ignition ..
the stock ignition uses quite a long "dwell" (evidenced by the ignitech software which defaults to "excitation = long" when setup for a zxr400 with stock coils) perhaps the dwell is excessive for the CBR coil sticks and is causing them to overheat when left idling..
at higher rpm it's less of an issue as the dwell is limited by the fact its time to spark again ..
I'm no expert with this stuff, but i recall TK400 going into detail on this in an old thread somewhere .. essentially coils have to be matched to the ignition,.. too little dwell and you have a weak spark at high rpm, too much and the coils overheat and cause a missfire.. for this reason, he suggested (having done the homework) using zx6r C1h coils as they "should" be compatible.. which is what i went with for mine... which i havent fitted yet.
ah ha !Neosophist wrote: Ok cool that makes sense to me!
ahh well ..Neosophist wrote: I've put the standard ZXR coils back on the bike at the moment and it's still turd :'(
