the lower half of my speedo is pretty dim but all the other clocks eg tach and coolant are bright as is the top half of the speedo. Does it have two bulbs in it or is this normal?.
Speedo bulb
Re: Speedo bulb
Hi, yeah there's two bulbs. You'll need to remove the front fairing and possibly the Clock dependin on which bulb has blown. You can pick them up from halfords just match up old for new. They are in place via a rubber seat which should pull out from the clock. Pull out old bulb and push in new. Check bulbs work before u put the lot back together! Job done.
