Ive finerly finished rebuilding the bike
Got it started nice and easy after new :
Spark Plugs CR9EIX / RedX Engine Flush / K&N Oil Filter KN303 / Filled Up Oil With Motul 5100 10w40
New Oil Pipes (tnx to baz ) / Fresh Coolant (mixed to correct ratio) / Refitted Stainless Exhaust With Sealent & Gaskets & Fixed 2 Broken Engine Bolts
Striped Carbs & Cleaned / Refitted Inlet Rubbers From Airbox To Carbs / Got New Idle Cable
Ok heres were the problems start, I start the bike it runs for 15 - 20 mins then the battery loses charge over that time, Seems to be running the bike off battery power only.
High/Low Beam Working But Goes Dim As Battery Dies & Doesnt Change Upon Reving It Up
New Xenon Purple Glow Bulbs With Fully Charged Battery Side lights perfectly fine 12v 9LED Purple Bulbs
Now after its been running the 20 mins the alternator leads get hot, And do melt a little rectifier end (alternator wires). Also the yellow/black earth pin off rectifier, Ive spoted it has melted the plastic around the earth pin, And the pin has slided forward a bit as shown in picture below
Ok at this point I charge the battery up AGAIN! Get the multi metre out, I checked the battery output @ full charge 13.8v YUASA Gel battery, Then I start the bike with everything pluged in check the charge on battery terminals 13.80v. Then I check the charge every 2 mins untill battery dies, It starts to drop slowly 0.20v every 10 mins. (NORMAL RUNNING POWER DRAIN
I Then start the bike again with lights off (All tho all wiring tests!) Getting weaker to start as it gets on proberly 5 - 6 starts, This time I check the output from brown wire for lights and accs @ Rectifier 12.8v - 13v. The white wire from battery @ rectifier should be around 14- 15 when running. (From Kawasaki Manual) I get 12.8v - 13.0v lower then battery voltage & does'nt rise when reving it up
So then i turn the bike off and check the resistance between alternator leads for a broken rotor magneto/stator coil (Should be between 0.2 - 0.9 @ 1 OHM & 10 OHM Resistance) Mines was 0.4 between all 3 pairs saying they are fine (From Kawasaki Manual)
Then I unplug all rectifier lead and check the AC current @ 200v with multi metre between each alternator lead I get 32v on tick over and goes to 100v @ high revs (The kawasaki manual says it should be @ 43v ish @ 4000 RPM But ive got no clocks
If the voltages are correct then alternator is fine
Tnx to anyone that can help
