Hello everyone,
I ask for help.
I need to know the exact sequence of wires going into the connector of the fuse box, especially the first connector on the left, not from the light to understand
would take a picture of the connector so that you see the colors of the wires or see in your ZXR 400 L model, and possibly communicate.
without this information can not easily proceed with the works of Rebuilding of my kawasaki ZXR 400 L1 (1991).
thanks to those who will give me a hand
wiring on junction box scheme
matilda54
- My Bike: kawasaki zxr 400 L1
thomp1983
- My Bike: zxr 400 l3
Re: wiring on junction box scheme
the wiring diagram with colours is in the manual which can be found on this site, there is also an internal circuit diagram for the junction box there aswell, it doesn't tell you exactly which colour goes to which pin but if you use the two diagrams together you should be able to figure it out, if not ill take a picture of mine tomorrow at some point
chris
chris
matilda54
thans chris,it'll be great if u can post a photo of your wiring also to work on my bike quikly.
certainly i'll post the done work.
there are a lots of woriking hors that only the passion can encourage.
thomp1983
photo's aren't much use due to how the loom is taped up so ill type the wiring colours for you. ive labelled the connector pins 1 to 10, number 1 is the top left pin, number 10 is the bottom right pin (as you look at your photo's), not all of the pins are used,
1, black/red
2, yellow/green
3, yellow/red
4, not used
5, not used
6, light green
7, not used
8, not used
9, green/black
10, green/white
hopefully that will help,
chris
1, black/red
2, yellow/green
3, yellow/red
4, not used
5, not used
6, light green
7, not used
8, not used
9, green/black
10, green/white
chris
matilda54
chris thanks for your help has been crucial to continue the work, but unfortunately not exhaustive and in any case anything were to serve for your ZXR 400 let me know that I have many pieces I have for the most in 'on my bike.
to continue the work I need the diagram also connect the other kings of the junction box (circled in green in the photo) because there must be some consensus there, too, without which the bike will not start.
thanks again for everything and I hope that with this additional help riesta to solve all electrical problems.
thomp1983
1 is top left again, 8 bottom right
1, white/blue
2, white
3, blue
4, brown
5, red/green
6, not used
7, not used
8, red/white
1, white/blue
2, white
3, blue
4, brown
5, red/green
6, not used
7, not used
8, red/white
ttpllo
- My Bike: kawasaki zx400g 1988
I have a ZX400G '88. I need help with CDI...
If anyone could post a picture or something about it, will be appreciated
