I've been given an old bike that someone else brought and could'nt get going
I've got a limited knowledge mechanically and im new to bike electronics
I've charged the battery and have 12v through the 30amp fuse
12v at the starter motor direct from the fuse
12v at the stop run rocker switch(both sides)
also 12v through the bodywork to the neautral(earth) on the battery. Is that normal?
no lights or dials are on the front of bike at present, but when i try to start it nothing happens, no noise no rear lights
Where do i start?
Thanks in advance
Project Bike
- Miles
- My Bike: ZXR 400 L3
Re: Project Bike
When you press the start button you should hear the starter relay click, if not start with that.
Also make sure it's on netural
- My Bike: ZXR400 1998
Re: Project Bike
Cheers Miles
No Click in Neutral also
no voltage at the horn or front lights but voltage at the start rocker switch and most of the wiring looms ive checked
Re: Project Bike
put the bike into neutral, ignition on, hit the starter button the bike should fire.
as yours isnt i would look at bypassing the starter solenoid as my first starting point, for this you will need to remove the LHS rear panel so you can access the solenoid, pull back the rubber covers on the two main terminals and with the ignition on bike in neutral use an insulated screwdriver to short out the terminals, it should visibly and brightly spark (you are basically shorting out the full battery so it will be noticible) and the starter should turn.
if the starter turns then your issue is with the solenoid, if the starter doesnt turn then either the starter motor is knackered, or you have no continuity between the engine and the -ve terminal of the battery.
Re: Project Bike
Cheers Banner
I have 12V at the starter between the +ve cable running off the soliniod and the -ve on the battery
When i tried to bypass the soliniod it didnt spark so i guess i have no continuity between the engine and the -ve terminal of the battery.
The only cable i have on the -ve of the terminal goes directly to the framework
There is no voltage from the positive battery terminal to the negative(earth) on the starter
Starter turns over if i run cable direct from the battery
- Miles
Re: Project Bike
Have look at the earth point next to the crankcase breather pipe
Re: Project Bike
Is the earthpoint next to the crank-housing a twin cable
i have some sort of sensor with a connection onto the crack but there is no continuity back to the -ve from either cable
the cable is sheathed but seems to be in quit poor condition
- Miles
Re: Project Bike
Yes, it's a ring terminal that bolts too the 'top' of the engine. A few inches from that is a bullet connector on the same cable
Re: Project Bike
it looks like you probably have a dead starter motor. you can test this by removing the cable that attaches to the starter motor and placing it on the engine, when you short the starter solenoid you should now get a spark...this indicates that there is a problem with the starter motor only.guernseydan wrote:Is the earthpoint next to the crank-housing a twin cable
i was on jersey last weekend for the holidays 4 heroes event and i had the exact this happen to my mates hyosung harly-knockoff, the main connection from the terminal to the first carbon brush had snapped so there was no current flowing through the motor. we soldered the brush back onto the terminal, then locktite'd the terminal into the housing, before splicing in a backup feed wire into the copper wires for hte carbon brush, drilling an exit hole in the side of the starter motor and adding a ring connection so it took thermal stress off of the broken copper wire...at 2am...when pissed...but it worked so he could ride
incidentally this is me on my mates 600 bandit chop with a full 2.5" of ground clearance on the island:-
