http://www.halfords.com/webapp/wcs/stor ... ryId_90898
Yes thats right, no more shall your home made paint job come off with a few spots of petrol, halfords recently released it, needs 2 weeks to cure before you can compound it and buffer. Well worth the money i would say.
Thought it would be usefulas i read a thread about someone spilling petrol on their tan whilst on the way to a track.
At last the time has come
Cloud Wolf
- My Bike: ZXR 400 L 92
- Xphyral
Re: At last the time has come
it's amazing the crap that gets sold to the unsuspecting public. almost all lacquers are petrol resistant once they've cured. note, "resistant"... if you leave petrol on there for a long time it'll still make it go white.
And why on earth would you ever even want to bother trying to cut, rub or buff a spray can lacquer finish.
not worth the money at all, buy the cheap stuff and leave it longer than a day before spilling crap on it.
whilst what you say is true ... of lacquer .. did you ever experience the awfulness that was halfords lacquer before this ? it was just acrylic paint without the pigment.. .. you couldnt buff it to a decent shine, and 2 months in the slightest whiff of petrol would strip it all off in a sticky mess.
this stuff isn't great, but it does work.. did the ZX-4 swingarm with wheel silver and a can of this.. and its holding up well.
- Xphyral
that wasn't lacquer
it was clearcoat, which like you say is just a suspension fluid for pigments in gloss finished paints. as a clearcoat it did it's job fine apart from the fact it was in a can. a paint suppliers will usually be able to put an acrylic based lacquer in a spray can for anyone, i can get any lechler paint i want in a spray can along with lacquer, problem is i cant use additives in a spray tin and the spray pattern isnt conducive to a good finish. clearcoat can be buffed up as long as theres enough to cut into and you dont overwork any area. Clearcoat can give a much more glasslike finish for show work but isnt good for durability. Acrylic based lacquers can get a decent finish and petrol resistance but need careful temperature control while curing plus additives if your short on time.
The best type to use for durability/finish is 2k lacquer, but this contains isocyanates which means most paint shops wont sell you it and it's really really unhealthy to be spraying it without a full body suit and an airfed mask in a professionally fitted spray booth.
Also waiting until a topcoat clear has fully hardened before cutting or buffing it is making more work for yourself, about 24 hours after the final coat was applied is a much better time and if you can still use a rubbing compound to remove overspray on a fully hardened lacquer then it's petrol resistance and durability is going to be absolute skunk.
yeh, im with you on that ..
personally my spray painting is split between quick n dirty halfords matt black jobs, or 2 pack and a compressor.. which is indeed incredibly bad for you, i was ill and
ing up nasty green gak for weeks after spraying my bike indoors with a shitty mask.
- Xphyral
i usually have bogies the same colour as whatever paint i'm spraying that day with any normal face mask, doesnt worry me too much though if it's not 2kzimm wrote:yeh, im with you on that ..
personally my spray painting is split between quick n dirty halfords matt black jobs, or 2 pack and a compressor.. which is indeed incredibly bad for you, i was ill anding up nasty green gak for weeks after spraying my bike indoors with a shitty mask.
