Just giving some panels a respray and i'm not sure which primer to use. The standard primer halfords have seems to be for metal. So i was looking at the plastic filler primer stuff? Anyone used this stuff?
Also what grade of wet nd dry do you go up to? The primer says about 600..then i was thinking sanding the primer down with 1200...... Thoughts??
Which primer/sanding?
lewisdale
- CBT slow
- My Bike: zxr400 H2
Re: Which primer/sanding?
i know people rant on and on about plastic primer but to be honest when i done my bike i used the normal stuff, that was about 4 months ago and the bikes constantly been outside in the ice snow and rain and not always covered and it hasnt peeled/flaked or anything
- zxrnoakze400
- My Bike: zxr400 h2
im respraying the l1 i got from carney at the moment and using plastic primer (halfords) and for the first rub down after stickers are all off im using 800 wet and dry, then when first primer coat is done using 600 for a second rub down, the 2 front fairings are almost done and look realy good! they are plain black at the moment but my cousin works in a sign writing company so im gona get some sexy kawasaki stickers made up !
