full throttle startings
FraZX4R
Post by FraZX4R »
hi everyone,
my bike needs full throttle to starts. I've already tried some mixture screw settings, but with no results. Any suggestions? biggrin
CaNsA
My Bike: ZX6R F1
Re: full throttle startings
Post by CaNsA »
Tried adjusting the idle?
check/set the valve clearances
FraZX4R
Post by FraZX4R »
the idle is around 1400 rpm, so it should be ok
and i'm not able (and really don't have the time :smt010 ) to check the valve clearances, especially if I'm not sure about the problem
Has anyone had the same problem?
P.S. i was wondering, in order to clean the jets, can i remove the float bowl without taking off the carbs?
thank you guys (and don't look at the writing mistakes please :smt003 )
