Hi guys i have the same the same problem as below but i have a uk bike and uk loom. i have checked continuity of the loom and all is fine the earth is fine and i have bypassed the sidestand switch. i have no spark and getting frustrated!!!!!! :smt013 :smt013 :smt013
HELP ME!!!!!!!!
Engine turns but no spark!!!!!
double-b
- My Bike: ZXR 400 L3
Re: Engine turns but no spark!!!!!
Exactly how did you bypass the side stand switch ? ?
The clutch switch is a possible problem
double-b
We just looped it. The clutch switch only cuts out when your in gear and pull away?
stevezx7r
- My Bike: 1992 (ish) ZXR 400.
Have a look at the starter solenoid fuse, it's a 30 amp pull out type - mine has blown a couple of times when I had the battery on charge while trying to start the bike. If you still have idiot lights then it could be something else.
double-b
Right got it started. If anyone does not realise the H model has a different ignition barrel there is a resistor in the L model which the ecu picks up then allows the spark! Now we have it started but runs like a bag of spanners!
I am assuming it is you that changed the ignition switch ? ?
Therefore you have asked us a question without giving us all the material facts........................
double-b wrote:Now we have it started but runs like a bag of spanners!
Errr, service time or has that been done already ?
double-b
Sorry Mori-man correct i have changed the ingnition barrell to a L model and bang it starts! As you say now time for a service and balance the carbs and a bloody good clean up.
