Hi all, just got my ZXR400'L3 and it for a few days then suddenly the bike die half way. The light are still on but just cant start and i can heard a buzzing from
the rider seat. later i change a new batt and found out it doesnt charge back , die again....
Could it be the rectifier/regulator , charging coil or fuel pump having problem??? could somebody post a pics of those 3 things pls??
Many THANKS! ! ! !
Need Help ... PLS !!!!!!!
Re: Need Help ... PLS !!!!!!!
welcome to the forum mate, defo sounds like the regulator/rectifier has gone, check it to make sure no wires are loose and its all properly connected.
If thats all ok then probably time for a new one.
ya time for a new regulator ... btw it is very expensive and hard to find 1 in Singapore cos ZXR400 is gonna extinct... most had been scrape or export out feel like im riding a legend on the road
Thanks for the reply . ZXR rocks
Dunno where you would get one in singapore, seak to a member il4,
memberlist.php?mode=viewprofile&u=51
i believe he is from singapore he may be able to help you.
I know this is an old post but I recently replaced my rectifier with the new upgraded one from the Kawasaki factory here in Japan. They sent it out to me in 2 days and it set me back about US$75.00... works like a charm
They also have ever part you'll ever need for all ZXR400's so if anyone gets stuck send me a message and I'll be glad to help.
you know what bullet
this is funny cos i have EXACTLY the same problem, just started for no reason, i haveto really REALLY push hard on the starter button to fire my bike up and even then, 9 times outta 10 it buzzes like an acid raver on a saturday night!
its like a real machine gun tat tat tat tat noise, and will fire but doesnt sound healthy,.....rectifier it is then!
B
B
- zxr_oli
- My Bike: Daytona 675
May not be relavent, but i've noticed that my fuel pump clicks when i start the bike without the tank connected
