dont know if this is a problem or not but at idle and in neutral, if i open the throttle fully, it gets to about 12000 then its like it misfires and the revs drop even if i keep throttle open. the neutral light also blinks in time with the "misfire"
is it supposed to do this? i wont know if it does it on the orad till the weekend but would appreciate any advice on this.
btw, i know you shouldnt rev it like that, i was doing it as part of the bleeding process.
cheers
mike
									revving problems
				rover220
 - My Bike: zx7r p6
Re: revving problems
Id wait untill you get on the road mate and see, if you dare open it up that much with this weather! I did the same over the summer with mine, with and without the derestrictor in, and the needle showed about 12000 rpm as it bounced off the limiter.
				rover220
 - My Bike: zx7r p6
so are you saying its normal or not? im guessing not...
its odd how the neutral light blinks in time with teh "misfire" and that the revs drop while still "missing". what could cause this?
will have to get it on the road at the weekend
cheers
cheers
Well im not saying either way, mine did something similar thats all. As i said, just get it out on the road and see how it goes.
				Northern ANdy
 - My Bike: Unique ZXR400
would guess that the action of revving it to such an extent in neutral, does something to the neutral sensor / its wires, and the bike is seeing that the sidestand is down, but the bike is in gear without the clutch being pulled in, so cuts the ignition, revs fall, bike then appears to be in neutral and it lets the revs climb, and so on.
Don't know how you can bare to rev it that high though
Andy
				rover220
 - My Bike: zx7r p6
that sounds entirely plausible, only way to see is get it on the road asap.Northern ANdy wrote:would guess that the action of revving it to such an extent in neutral, does something to the neutral sensor / its wires, and the bike is seeing that the sidestand is down, but the bike is in gear without the clutch being pulled in, so cuts the ignition, revs fall, bike then appears to be in neutral and it lets the revs climb, and so on.
btw, it loves the revs but admittedly it shouldnt be done on idle, and its not something i do all the time.
ill hopefully take it out tomorrow and will let you know
cheers
				rover220
 - My Bike: zx7r p6
actually, it wont be that, the stand was up as it was on its paddock stand at the time.
