fitting fork compression adj.? LEAK-PROOF seals?
grey zxr400l
anyone install a racetech lower fork comp. adj.? http://www.racetech.com show the part to fit a zx7 & wonder if it will work on the zxr400.or modify the dampening adjusters to allow compression adjustment by other means. are the leak-proof seals any better than stockers?
the-elf
I've just had some compression adjusters fitted. Nice neat job as well. I've gone for a full Ohlins internal setup. I doubt that the adjusters would work with the standard internals as they don't have the adjustable compression bits in them, Hence the new internals in my forks as well. It'll be interesting to see how they perform on the track.
If your interested in a set then contact Russ at Mick Gardner Racing and tell him that Kev sent you.
