carbs jetting
swadger25
carbs jetting
Hi all just starting to rebuild my cv carbs on race bike . I'm going to be running ram air and trumpets both rmkd. Can any one help me for jetting Etc thanks
shaggy69
- My Bike: ZXR 400 Racebike
Re: carbs jetting
Hi there m8, on a standard engine with Ramair I was running 107.5 keihin main jets. Now with head work done I'm down to 102.5 main jets. It runs tiny bit rich top end on the dyno but felt perfect on road at the Manx GP. Hope this helps baseline wise.
Regards Shaggy
Regards Shaggy
swadger25
Re: carbs jetting
Hi there have 0.5 oversize pistons . Slight head work. Swona exhaust system ram air . Think have 110 mains .
stuzx4r
- My Bike: zxr400sp race bike
Re: carbs jetting
Hi, every bike will be different, BUT a good starting point is air jets blocked and 108 mains, standard pilot jets and needles with the air mixture screws out 3 1/2 turns.
A drip to your local dyno is then the only way to fine tune things.
Good luck.
Good luck.
- pre89racer
- My Bike: zxr400h1
Re: carbs jetting
hi iam runnin a stage7 dynajet kit, 132mains , got airram and stacks, je 1mm overpistons, head ported n flowed, sp cams, runs great but i want
to put it on a dyno. has anyone else used this kit and if so what set up did you find best?
