ZXR400 6pot Tokico upgrade.
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Post by Mori Man »
If you happen to have an ZXR you can do a direct swap over from your 4pot to 6pot Tokico's that are mounted on the ZRX400.
These 6pot calipers are standard on ZRX400 from 1989 (E4) so if you happen to find one in a breakers see if they still have the calipers on it.
I run mine with a 19mm Nissin radial master and they have saved my skin 3 times in the past month - with out them I would of been toast on two of the occasions and a very long hospital visit on the 3rd :smt018
You can also bolt the discs straight onto your wheels too :smt003
You can also get caliper adaptors of the shelf here that will allow the bigger 6pot Tokicos from ZRX11/1200's and XJR's to fit on.
Will have images soon :smt002
Thats interesting info and a mod i'm sure will be very popular with users here, thanks for sharing that info.
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Post by Mori Man »
Sorry I put it in the wrong place!! Doh!!
Should have them bolted on the forks on Friday, they are going to look so :smt007
If discs are getting harder to come by then Sunstar do a very nice range that bolt straight on as well - both sets of my discs are way to good to justify buying the now :smt012
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Post by Mori Man »
Just had a wee hunt about just to make sure my info' is sound :smt002 .
So, pre 98 ZRX400 have 4 pot 55mm spacing calipers so no good/advantage.
'98 onward bikes are 62mm spacing same as ZXR400H's :smt003
Had a look around the used market to see what was available and there is oodles of 6 pots you can bolt on with adapters. Most are 90mm spacing with the 62mm plates on them.
The Nissin 6pots are just pure "porn" in gold or that gunmetal grey colour.
Don't know what you would pay out of a breakers in the UK for a set of 6pot's - here they start from around 215 GBP a pair for Tokicos and about 250GBP for Nissins
If some one can tell me the centre spacing on L models ect. I will find out what else can be bolted onto them too! :smt002
L and H model spacing is the same, just the H model calliper can accomodate a slightly larger pad :)
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Post by Mori Man »
RobB wrote:L and H model spacing is the same, just the H model calliper can accomodate a slightly larger pad :)
Could you do a little Admin' magic and ammend the title to All ZXR400's 6pot upgrade - or words to that effect :smt002
diesel
My Bike: Zx7r
Post by diesel »
i got an H1. does that mean i can use 6pots?
Quicker Than Yngwie
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Post by Mori Man »
diesel wrote:i got an H1. does that mean i can use 6pots?
Here they are on my H1 forks - wheel will be fitted tomorrow :smt003
But when funds allow I do fancy putting a pair of these on :smt007
Just don't know what colour???
ive got a sudden urge to ermm......ill be back in a minute.
diesel
My Bike: Zx7r
Post by diesel »
me too, make room for me.
Quicker Than Yngwie
gubbs
My Bike: ZZR1100C3
Post by gubbs »
... pass the toilet paper!
zxr400 h2 (breaking)
zzr1100c3 (broken)
Vespa et4 (almost broken)
My FleaBay
Northern ANdy
My Bike: Unique ZXR400
Post by Northern ANdy »
pads look expensive...
does it stop any better? and what is the length of your master c
Andy
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Fitted
Post by Mori Man »
Here is how my Tokico's look all bolted up.
To answer Andy's question: These are the same spec as the ones fitted on Hayabusa's , however on my ZRX the master cylinder was a regular 5/8th which was good but the 19mm Nissin radial I fitted brought out the best in them :smt003
Kwak pads are about 26 quid a side.
Aftermarket about 62 quid a set.
The Nissins I am not sure on!
They feel fantastic with the USD's , I always thought the stanchions on the RWU's were gonna break under heavy use!!
And to top it off those are SP forks too!
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Post by Mori Man »
RobB wrote:And to top it off those are SP forks too!
Didn't know that! But I did order the overhaul kit for H1 forks???
What's the difference with SP units then?
Cheers DS :smt001
