H1 with ZX4 Engine
ZX4R-F3
My Bike: 1988 ZX400-F3
H1 with ZX4 Engine
Post by ZX4R-F3 »
Hello,
This is my build project started with a ZX4 idea was to rebuild it but parts are a few and far between :smt012 , was going to fit the H front end also rear end, long story short ended up getting front end, rear end and frame with sub frame so basically turned into a H build with ZX4 engine :smt003 . Frame, sub frame, wheels all powder coated, frame is satin black. All bearings replaced, engine recon from head gasket up. Various parts polished by myself. 636 rear shock fitted also has the 400 spring fitted so it doesn't rub the swing arm. All work done by myself, it's taking shape nicely i think, all comments welcome.
Thanks for looking,
Andy
Reason: Changing photo format
Re: H1 with ZX4 Engine
looking good, i like the way you have managed to fit the hugger on :smt003
ZX4R-F3
Post by ZX4R-F3 »
Quick update.
Oil, Coolant and Fuel in, couple of spins on the button and fired up, no leaks no rattles :excited
Fairings to paint and brakes then MOT.
Andy
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Post by Mori Man »
Thats looking well good - do like the Satin frame and matt engine :smt007
Damn your hide for showing !! :smt013
MM! :smt003
ZX4R-F3
Post by ZX4R-F3 »
Cheers, RedexRob should keep some of the road grime off the hard to reach/clean parts.
dazzx10r
My Bike: ZX10r race bike, ZXR400L9
Post by dazzx10r »
Looking good, loving the green spring on the rear shock :smt004 what year 636 is the shock from? I have a 2007 zx6 shock in mine with a custom made spring but I've managed to chip most of the paint off it! Keep the pics coming! I'll get my 400/636 project outside in the daylight tomorrow for some more pics. :smt001
ZX4R-F3
Post by ZX4R-F3 »
Thanks MM Much appreciated i went for the satin as it has the subtle sheen and matt engine so the polished parts would stand out a bit shame won't be able to see most of it when the fairings are on, but at least i know they are done.
Has it given you an idea for a new project :excited
Cheers,
Andy
ZX4R-F3
Post by ZX4R-F3 »
dazzx10r wrote:Looking good, loving the green spring on the rear shock :smt004 what year 636 is the shock from? I have a 2007 zx6 shock in mine with a custom made spring but I've managed to chip most of the paint off it! Keep the pics coming! I'll get my 400/636 project outside in the daylight tomorrow for some more pics. :smt001
Hi Daz, the 636 shock was listed as a 98 to 02 A1, The shock is 30mm longer than the 400 shock, I just put the height adjuster to it's lowest point. I had to drill the top mount out to 14mm I think :smt017 to fit the ride height adjuster same on bottom fitting. As for the spring it has been powder coated, fitting was not a problem I used ratchet straps on each side to compress removed bottom spring retainer, stand well back and release straps. The 636 spring is shorter and wider and rubbed on the swing arm so fitted the 400 spring a bit longer but right width. specs say 12-24mm preload if i remember correctly which is within the limits with adjuster rings near the top of the shock. also has the benefits of three way adjustment without it being rock hard and shouldn't bounce me out of the seat with the amount of potholes about.
ZX4R-F3
Post by ZX4R-F3 »
Hi been a bit of slow progress lately but still plodding on.
Quick update,
VIC check done by VOSA for DVLA just to get log book.
Carbs cleaned and re-jetted and Quill end can fitted.
Revs smoothly now and no splutters.
Brakes fitted with venhill lines, i like the way the banjos and lines fit together so no line twist.
All bolted and torqued up, just prep and paint to go.
Then thought i would run it round the block to see how it performs, big thumbs up and smiles no rattles nothing fell off and sounds great. :excited
Here is the vid of the first run.
http://www.youtube.com/watch?v=PD9xYd9VsqI
Cheers Andy.
ZX4R-F3
Post by ZX4R-F3 »
Quick update.
Mechanically bike is complete, just the prep and paint to finish. Aiming to MOT it beginning of April, then a month to fettle any bits and on the road for May.
Front mudguard painted, also top cowling.
Here are a couple of pics to show colour and finished piece.
Click image to play video.
Let me know what you think.
Thanks,
Andy.
ZX4R-F3
Post by ZX4R-F3 »
Hi all,
Just a quick update on how it is going, still on target for getting it on the road for May.
Andy
CaNsA
My Bike: ZX6R F1
Post by CaNsA »
Looking bloody good. :smt004
Where did you get the rad mounts from?
ZX4R-F3
Post by ZX4R-F3 »
by CaNsA » Mon Apr 02, 2012 8:41 pm
Hi CaNsA,
The rad mounts are off my ZX4, I just stripped the paint off polished them up and painted the recessed bits.
Andy
ZX4R-F3
Post by ZX4R-F3 »
Just a teaser.
Quick mock up to see if panels fit (not quite) bit of fettling to do.
Nearly there. :smt003
ZX4R-F3
Post by ZX4R-F3 »
HI,
Just a pic to show how it's going.
