decide to try and finish up Turtle
in case anyone might be interested, i'll list the things done at the bottom for reference.
Anyways... Drew has been super as usual and got me a sleek set of titanium Beet downpipes.
I bolted on a set of titanium K-Factory GP can to finish off the zorst setup.
reckon she's at high 60s or low 70s bhp right now on dyno.
last dyno was around 65 bhp before the exhaust change and carbs syn.
performs like a gem on the tracks.
some idea of how she sounds like now.
Pity the carbon fairings didn't fall through since the vendor didnt deliver.
anyways, heres some pictures of how she looks like now
Things Done
Handling
ZXR 400 SP Rear shock *Re-valved*
Tsukigi copy CNC rearsets
Steering cone / Bearings
Fork oil/seal/ dust cover
Alignment of rims *front & rear*
Dunlop Alpha12 Tires
Wheel bearings
Swingarm bearings
NHK Steering damper with mounts *not installed yet*
Carbon Goodies/Weight Reduction
Carbon style mini brake reservoir
Carbon yoke protector
Titanium bolts *Full Fairings*
Titanium bolts *Windscreen*
Titanium bolts *Fuel tank cap*
Titanium bolts *Rear Hugger*
Titanium bolts *Chain Guard*
Titanium nuts *Sprocket*
Coerce Carbon fender and chain guard
SP Single seat cowl
Brakes
Brembo RCS19 master cylinder (front)
K3 GSXR750 calipers (Front)
Caliper bush (Front)
Brembo master cylinder (Rear)
Venhill brake hose (Front & rear)
Braking cm55 pads x2
Braking front rotor *WK006R, WK006L*
Cooling System
Samco sport hose & clamp set
Water wetter coolant
Power up/Engine Misc
BEET titanium exhaust headers
K-Factory titanium GP end can
K & N airfilter
SP Camshafts
Dynojet kit *Stage 1*
Afam Sprocket *15 Front*
XAM rear Sprocket *47 Rear*
K & P Performance Oil Filter
Porting
Skimmed cylinder heads
Fuel Broquet 8t
Engine overhaul
Top Engine replaced
Clutch rebuild
Clutch gasket
Clutch cable
Steel plates
Friction plates
Clutch housing
Electronics
Main wire loom
Sub wire loom
EarthX Lithium Battery
Maintenance/Rebuild/Misc
Shorty adjustable levers (brake & clutch)
Headlight protector
Throttle cables
Anodised titainium billet chain adjuster block
Copper exhaust gasket x4
Carb rebuild kit x4
Fuel filter
Fuel pump
Fairing infill
Denso Iridium plugs
Stainless steel L shape tire valves
DID X ring gold chain
Swingarm bobbins
Cush drive
Mirrors *Stock*
Bagster tank bra
Starter motor
MRA Bubble screen
