(And yes, that is me, and no, I'm not trying to look mean, I'm squinting against the sunlight)
Servicing.
??/05/2008 - Cam Chain and full service by Elliots of Cricklade @ ~33,000 miles.
??/05/2009 - Oil and oil filter change - genuine Kawasaki oil filter, normal semi-synthetic Magnatec 10w/40.
??/05/2009 - New Tsubaki chain and Renthal chainwheels.
12/05/2010 - Head Gasket replaced - genuine Kawasaki item.
12/05/2010 - Full service - Genuine Kwasaki oil filter, fuel filter, water filter, Castrol Power 1 Racing 10w/40.
18/05/2010 - Replaced sprocket carrier bearing - new Koyo 6205zzc3 metal sealed bearing.
Current Spec.
+ Bridgestone Battlax BT-020 front and BT-92R rear,
+ Micron full stainless steel race exhaust system,
+ Rejetted with Dynojet #92s
+ UKDM spec CDI,
+ UKDM spec Odometer,
+ JDM carbs,
+ JDM standard cams,
+ Early L model high compression pistons,
+ Early L model crank shaft,
+ Renthal 47 tooth rear chainwheel,
+ Renthal 14 tooth gearbox chainwheel,
+ EBC Pro-Lite discs and pads,
+ Aftermarket fairings,
+ Black double bubble screen,
+ [Tail tidy,
Motrax LED tip rear indicators,
plate mounted reflector,
LED number plate bolts
Renntec Grab Rail in white]
Modifications Already Done.
+ UKDM CDI unit.
+ UKDM Odometer unit, acquired reading 45093m, JDM unit at swap reading 58720km.
+ EBC ProLite discs, front and back.
+ EBC FA180 pads front
+ Micron full stainless steel racing exhaust - headers, link pipe, end can.
+ Renthal 47 tooth rear chainwheel.
+ Renthal 14 tooth gearbox chainwheel.
+ Bike-it black, standard length brake and clutch levers.
+ Motrax RSend tail tidy.
+ Motrax LED Tips rear indicators.
+ LED number plate bolts.
Modifications Acquired.
+ Goodridge braided brake hoses for the lower hose sections
+ Flush mount indicators (EBay special).
Modifications Planned.
+ UKDM Carburettors.
+ H model Sports Production or ZX4 model cams.
+ Goodridge braided brake hoses all round.
+ Respray in same colour scheme, but proper Kawasaki Lime Green.
