sp engine/ box
				Jackh2
 - My Bike: zxr400 h2 1990
sp engine/ box
How do I tell if my bike has a sp box? I've been told the lumps replaced with a sp lump, I know gear ratios will be different also heard that they run slipper clutches? Truth or bull? , if it is a slipper clutch will there be any visual difference when looking in from the clutch cover? Thanks in advance
				ross46
 - Restricted
 - My Bike: zxr 400 l6
Re: sp engine/ box
The slipper clutch on the zxr is SBATL something like back axle torque limiter, sp gearbox runs a 16 tooth front sprocket, you can check the engine number on here aswell
Re: sp engine/ box
I've got SP gearboxes in two engines....................in both cases the engine number will reveal that they are NOT SP
just saying
						just saying
				ross46
 - Restricted
Re: sp engine/ box
Could also get an sp engine with a standard gearbox
