What can you safely soak an O-ring chain in?
- Smousley1995
- My Bike: Zxr 400 L 1993
I've got a DID x-ring chain that I need to properly clean, what can I leave it to soak in that won't damage the rubber?
Also how does everyone clean their chains? I usually spray it with castrol chain cleaner, give it a good wipe and a spin and then lube it but this doesn't get all the crap out very well, just makes it gold and shiny again
I know a lot of people who say they never clean a chain and just lube it somive never considered it to be abusing my chain but I do love a very clean chain!
And I can't soak it n the castol chain cleaner because it evaporates too quick and would cost too much.
Cheers!
Cheers!
Why take life so seriously, your not going to come out alive!
Re: What can you safely soak an O-ring chain in?
Diesel or paraffin do an all right job.
I never clean mine , gets a dry lbe when the rings look they need it and that's about it.
Chain on my RG is a non O ring , 2yrs old , 7,000miles and rusted to hell
ZXR is O ring 5yrs old not sure the miles , got some surface rust only one tight spot
i used to use chain lube, but it can be a pain to get off when it splatters everywhere.
now i just use a bit of used engine oil and a cheap 10p supermarket toothbrush to work it into the chain (top, bottom and both side plates), chains been on the bike for 2 years and done 12,000 miles with no visible wear to the front steel sprocket, and only a small amount of wear to the aluminium rear sprocket, if i try to pull the chain away from the rear sprocket there is almost no give.
no rust on it, and i use the bike all year round, in all the salt and general road crap in the UK.
- Smousley1995
So diesel or paraffin definitely won't damage the o-rings?
And everyone always says about the splatter but I use castrol chain spray O-ring and that's sprays on well and then turns a tacky waxy substance and I never have a problem with it flicking! I love the stuff! It is £8 a can but that's not so bad.
You will get splatter no matter what you use i find, so i just live with it.
As for cleaning i use muc off chain degreaser and a tooth brush, but really most degreasers do the job of getting old oil off you will need a tooth brush for the nooks and crannies. Muc off also washes off with water so a light spray with hose and the chain is gleaming afterwards.
To lube i use scottoil. Appky to a clean toothbrush and work it in. The chain on my versys had this treatment and was on 24k miles when i sold it. It could probably have been changed by then but was still good.
'esus , toothbrushes - I have missed that memo !
Of course Diesel & Parrafin OK - if not all combustion engines and burners would have problems with it destroying seals !
Used oil contains spent carbon and that is corrosive , never use as a lube or cleaner - as a quencher to blue steel , ideal
The whole point of doing an oil change before laying up your bike is to rid your engine of as much burnt carbon.
MM!
MM!
maybe true, but ive never had a problem, and its free...
Used engine oil is carcinogenic....................but then what would I know I'm only a dumb stupid IOM road racer.
Am I correct to believe that the X ring is intended to keep lubrication in the rollers as well as contaminates out. Surely therefore a harsh solvent would get past the x ring and dilute the lube in the rollers ?
Some good advice here.......................funny what even a complete idiot can find with google
http://www.sprocketsunlimited.com/Chainmaintenance.html
- KwakKwak
- My Bike: ZXR 400L9 2001
They are what is commonly known as lazy bastardos, it's bloody easy to clean and lube a chain, I'm using Silkolene cleaner and racing lube, makes me sound faster, you'll always get crap coming off the chain.Smousley1995 wrote:I know a lot of people who say they never clean a chain
Having just had my swingarm and chain (endless)off, I can be completely smug about having given mine a damn good clean and lube.
so is oxygen, and so is petrol.cargo wrote:Used engine oil is carcinogenic
i bet my exposure to petrol vapours is worse than my exposure to used engine oil, given that i wear nitrile gloves when working/cleaning my bikes.
- KwakKwak
I wear these gloves too, irony is I take them off to have a ciggie
I'll give up on breathing and sniffing petrol too then but I'll keep dumping the used oil down the toilet
Yup, sealed O ring means just that any cleaning is just for the outside and lube is for keeping the O rings moistcargo wrote: Am I correct to believe that the X ring is intended to keep lubrication in the rollers as well as contaminates out.
I guess people don't use google as they want to log into a forum and interact with peeps riding the same bike as themselves or are forums just libraries , you come here , shut up and just search & read ?
MM!
- Smousley1995
We'll by creating this thread I've given all of you something to do, to help me out and also it seems let off some steam which is always a good thing I was also interested in what everyone else did with their chains and some useful tips you can't find on google.
Thank you very much cargo! I never knew that so I think I'll skip the soaking part and use lots of elbow grease on it.cargo wrote:Am I correct to believe that the X ring is intended to keep lubrication in the rollers as well as contaminates out. Surely therefore a harsh solvent would get past the x ring and dilute the lube in the rollers ?
I love nitrile gloves! Saves me scrubbing my hands for 10 minutes whenever I work on the bikebanner001 wrote:given that i wear nitrile gloves when working/cleaning my bikes.
Top Cargo tip
W5 hand cleaner is THE single most best hand cleaner you can buy..................sadly it seems to only be available from Lidl occasionally so watch out for it. It's cheap as chips too.
