I am having difficulty adjusting my clutch cable.
I have adjusted it both ends but it either stalls as I feed the clutch out or it pulls away with the lever on the bar. It is a new cable ordered through wemoto.
Anyone else had problems or can anyone provide a pic of either end of their cable on the bike so I can check mine.
Wemoto clutch cable
- My Bike: Honda Bros 650
Re: Wemoto clutch cable
Have you possibly messed with the clutch switch during fitting ?
the only way it can pull away when the lever is up against the bar is if the cable is too long, in other words, even pulling the cable back is not disengaging the clutch, which means that you have either adjusted your clutch cable incorrectly, or you have been given/ordered the wrong cable for your model.
what model is your zxr400, l or h, the cables are different sizes and the OEM h is no longer available, maybe wemoto got them mixed up?
I have a L5.
Thanks for the replies.
