Hi All.
Firstly hello and please excuse if i'm a bit of a noob as this is the beginning of a learning curve for me.
I've just purchased my first project bike! A ZXR750 J1. Needs a bit of TLC.
It came with a replacement ignition as the guy snapped his key in the last one. The engine started on the last ignition perfectly... but i didn't like having half a key. So after replacing it I saw the lights come on on the turn of the key and thought it was a winner, end of, job finished. I threw away the old part as i didn't believe I needed it. (I now understand to be a MASSIVE mistake.)
Came back to it this week to have a tinker and show off my new handy work to a mate we discovered it didn't start.
Thinking it was just petrol I topped it up with £5. Still not working.
The fuel pump is pushing fuel. I can hear that click and then stop.
I dont think the coils are faulty as they worked with the previous ignition.
I've tested for a spark and Im not getting one. even with different / spare sparks.
I've now noticed the new ignition has different colour wires to the original. (Obviously i would love to have the old piece here to compare... noob mistake)
The bike is after wires that are coloured.
1. Orange and Green
2. Blue and Brown
3. White and Black
4. Red
5. Grey
6. White
And the brown ignition switch. From seeing the Haynes diagram this is correct.
The replacement part I received came Like the link below.
http://www.ebay.co.uk/itm/Ignition-Swit ... SwpzdWsyJs
1. Brown and White
2. Black
3. green
4. Red
5. Grey
6. Orange
And the Brown Ignition Switch
The connections are made 1 to 1, 2 to 2, 3 to 3 etc... on the normal connector. I'll add pics PLEASE SEE ATTACHMENTS.
I cannot find a diagram of how the New ignition is wired but the ebay page says it suits the bike.
I've hunted down different specs to see if have the wrong ignition but cant see these colours on any other bike so far.
Has anyone else had this issue? Am I missing something really obvious? I could test the individual pins to see what output Im getting but don't know what levels im looking for.
Any help is appreciated.
Thanks in advance!
Mike
ZXR 750 J1 Ignition Issue
- My Bike: ZXR 750
- CaNsA
- My Bike: ZX6R F1
Re: ZXR 750 J1 Ignition Issue
- My Bike: ZXR 750
Thanks CaNsa! Yes this is the Diagram i am also working from in the Haynes manual.
Mike
all your ignition switch is doing (that you are interested in) is sending power from the white wire from the loom to the grey and brown wires of the loom when you turn the key to on...thats all it should do, the other wires are for turning your instrument lights and other bits on...of no importance as far as you are concerned.
as your fuel pump comes on when you turn the key im assuming that the connections you have made with the white wire and brown wire are fine, its likely that the one to the grey is therefore also fine...however most bikes have a resistor in the ignition barell to drop the voltage down the grey wire, this goes to the ignitor and prevents someone just hotwiring the bike with a bit of wire going from the white wire to the brown and grey wires...so you need to find what this resistor is.
on the zxr400 you need a 1W 100ohm resistor (see picture #13 viewtopic.php?f=125&t=15674) added to the grey wire, this fools the ignitor into thinking that the ignition barel is attached, and that the correct key has been inserted and correctly turned to on...the 750 will want something similar, ill look around for race loom mods and see what i come up with
at the very least i would stick an ohmmeter across the white and grey wires of your ignition barell, check the number, then do the same between the white and the brown wires, you should see more resistance with white to grey, than white to brown
- My Bike: ZXR 750
banner001 wrote:all your ignition switch is doing (that you are interested in) is sending power from the white wire from the loom to the grey and brown wires of the loom when you turn the key to on...thats all it should do, the other wires are for turning your instrument lights and other bits on...of no importance as far as you are concerned.
Ok,
Interesting. So it would seem the switch may actually be ok. I'll have to search for the resistor, I'm assuming its in the ignition barrel unit.
I'll crack it open and see how we get on.
Thanks for your help! I will let you know.
mike
zx7r seems to have something similar, it should drop the voltage out down the grey wire to 6V, you can test the voltage output down the brown and down the grey wires wen the key is turned...that should also help you.
just check the resistance between the terminals of the block connector when its not connected to the loom and the key is turned to onmikethegent wrote:banner001 wrote:all your ignition switch is doing (that you are interested in) is sending power from the white wire from the loom to the grey and brown wires of the loom when you turn the key to on...thats all it should do, the other wires are for turning your instrument lights and other bits on...of no importance as far as you are concerned.
Ok,
mike
- My Bike: ZXR 750
After much testing!banner001
It turned out that the multimeter was showing the correct connections when in the 'ON' position.
Although the connections were correct I didn't see a different resistance. (I think... remember I'm very junior to this.. )
In light of this i thought I'd buy a replacement ignition that i could then take back if that didn't work. I had the correct colour wires and the bike fired up first time. Winner.
So can I assume it was the resister in the ignition?
New switch Loom
Grey and Green = Grey and White = 0.08 ohms
Red and Black = Red and Blue = 0.08 ohms
(Brown with white) and Orange = (Orange with Green) and white = 0.08 ohms
Just want to thank you guys for your support! Thanks Banner001!
I'll pop a pic up once the bike is looking like it should!
Mike
