Wet/oily spark plugs?
- My Bike: Kawasaki zxr 400 L6
Just bought a zxr 400 L6 from a mate and it runs sweet as a nut, but there is a mysterious oil leak on front if the engine which seems to wet the while front.
We took tank of to get to the plugs, and when pulling thsm out to check them they were all wet with im guessing oil.
that meant to happen? Or if not can someine offer a solution? Bike not on road yet but about to finish my test
ZXR 400 L5
Re: Wet/oily spark plugs?
Check the seals between the rocker cover and the spark plug wells. There's a drain hole for each spark plug well that's on the front of the engine below the headers
As per what bendog said, there are 2 seals per spark plug tube, one between the rocker cover and the removable spark plug tube, and an o ring around the spark plug tube where it seals to the head.
You might want to err on the side of caution and replace the rocker cover gasket at the same time.
So on removing the rocker cover i can easily get to seals? Wheres thr best placr to get them?banner001 wrote: βMon Aug 28, 2017 5:50 pmAs per what bendog said, there are 2 seals per spark plug tube, one between the rocker cover and the removable spark plug tube, and an o ring around the spark plug tube where it seals to the head.
ZXR 400 L5
So it aint leaking oil as such just draining oil that shouldny be there?banner001 wrote: βMon Aug 28, 2017 5:50 pmAs per what bendog said, there are 2 seals per spark plug tube, one between the rocker cover and the removable spark plug tube, and an o ring around the spark plug tube where it seals to the head.
ZXR 400 L5
cradley kawasaki (http://www.kawasakioriginalparts.com/ro ... country=gb)
you need:
11009-1733 if oil is getting between the rocker cover and spark plug tunnel
92055-1403 if oil is getting between the spark plug tunnel and the cylinder head
11009-1732 if oil is leaking around the rocker cover
you need:
If your removing the rocker cover for any job , order a new gasket ( unless it's been changed recently ) as it has now been revised and gives a better seal.
excellent, which gaskets/oil seals did you change in the end?
Sorry for long reply mate, basically qll of them main gasket, the o-rings and the washers, they were all as hard and stiff as plastic... defo needed a change
ZXR 400 L5
For the minimal cost, and lifetime of the seals, it's a bit of a no brainer unless your proper skint at the time
