I'm a new rider from Austria near Vienna, but since the german forum is kinda dead and doesn't accept new members, I decided to join here
But let's get to the issue at hand (which seems to be a common one I guess?)
When the engine is cold everything seems to run normal but after warming up, there is a rattling sound coming from the right side of the engine. It is usually not audible below 2k RPM or above ~4-5k RPM (but it might be the engine sound overpowering it), doesn't matter which gear, moving or not or clutch pulled /not, it is simply dependent on the RPM (also the pitch stays the same if that makes a difference). I uploaded a video to maybe clear things up a bit: https://youtu.be/ViAINe5L7sg (the recording is not perfect but it definitely doesn't sound normal).
I assumed that the chain might have gotten too loose but wouldn't the tensioner be extended fully in that case? I checked it (cold) and it was only about halfway: Even after warming up, it was not fully extended(but more than when cold, because heat expansion I guess) I bought the bike in mid-october 2019 and the previous owner told me about the rattle before the purchase but then said he fixed it (which it was for a short time). Stupid me shouldn't have bought it but after a test ride I just wanted to have it
Don't know if this is related, but he told me they replaced two rocker arms (can send pic, they were really worn out
Anyway, I hope anyone can help out, should I just replace the chain, the tensioner, or both? Or is it something entirely else
