Just don't over-tighten the sump-plug - they're prone to cracking... =o|
Personally I will recommend motul 15W40 semi-synthetic engine oil for older bikes.. I've used Fuch silkolene 10W40 for 2 oil changes only and my mechanic tells me that my cam shaft need to change..Loopy wrote:I'm female![]()
but if its that easy![]()
I'll get new clutch then and also do an oil change same time just to make sure, what oil do u recommend for the old zxr?
