Mysterious whining!
It could just be some gearbox whine...
A lot of times after you work on a car or bike, you put it back together and take it out, and because you're a bit paranoid over it, you'll pick up on a sound that was always there but you just never listened for it before!
I was speaking to a mechanic a few weeks ago and was surprised when he said the same thing!
I've never seen sprockets with rubber on them. I wouldn't advise putting any on that's not factory fitted, either!
I can't see any advantage to having rubber on - if anything it's just more likely to make the nut ease itself loose as the rubber gives...
The front sprocket slides over the splines, so I can't see any advantage at all to having rubber on it?! Unless it acts as a spacer - but then I wouldn't have thought you'd get a whine, or if you did it would be constant?
its probably an anti-vibration thing?
deviant
Post by deviant »
thing is, the play (and hence vibration) of the sprocket isn't controlled by its width, it's controlled by the play of the splined plate/washer thingy in its groove. The sprocket is just bolted up to that, so I don't see why it would rattle any more or less.
Xphy - That was my first thought, because I changed the screen at the same time, but i'm fairly sure its not - makes no difference where I move my head, tuck in, etc.
Jamz - it wasn't doing it before. Absolutely certain.
Umm... just another thought...
I changed my chain and sprockets on my VFR a few weeks ago, and the other day when I was banked over to the left and on the power, I could hear a strange sound coming from the chain/rear wheel area.
I'd never noticed it before, and don't think I have since, but I had a good look over it all and noticed one edge of the chain had a polished look to it.
I worked out pretty fast that it was rubbing on the plastic chainguard - which it hadn't been doing when the chain adjustment was at it's longest wheelbase point!
Could it be that moving the wheel all the way forwards for the new chain is doing the same?
I think the L models have a plastic chainguard, if I remember correctly, anyway!
