It's got new pads + fluid, don't believe there is any air in there (also did the same b4 i changed the fluid), but it doesn't start braking until really close to the handle bar. Braking power doesn't seem to be affected, just the point at which is brakes.
Could this be the master cylinder allowing the fluid back again when the lever is let out?
