Suspension problem..... please help
keeton.
My Bike: 2002 zxr 400
Post by keeton. »
hi guys
had a few problems with the suspension on my zxr, so i measured the seat height and its 5cm lower than standard :smt012
are there lowering/jack up kits for the zxr that could of been put on? also could the suspension been set up to be that low?
can get photos if needed
any help greatly appreciated
keeton
2002 zxr400
Broken.
hciR
Re: Suspension problem..... please help
Post by hciR »
There's a ride height adjustment where the top of the shock mounts to the frame. It basically make the shock longer or shorter to change the height of the seat. I'd imagine you'd need to take the load off the suspension before adjusting it
keeton.
Post by keeton. »
thanks for the reply. what adjusting the ride height affect how the shock/spring work or need adjusting to how i ride?
2002 zxr400
Broken.
keeton.
Post by keeton. »
bump....
also has anyone got a picture of the bit i adjust?
2002 zxr400
Broken.
Dazzle
My Bike: Kawasaki ZXR400 L3
Post by Dazzle »
Hi if you look at your rear shock above the spring there is a mounting bolt that holds it to the frame you may need to take your seatand undertray off to see how much adjustment is there. It shouldn't affect the spring/shock unless you wind the thread up on the actual spring adjuster which isn't the bit you want to be looking at yet :smt001
keeton.
Post by keeton. »
http://cgi.ebay.co.uk/KAWASAKI-ZXR400-R ... 1|294%3A50
just for the picture, but is it that silver bolt on the top?
2002 zxr400
Broken.
thats the top mounting bolt :)
keeton.
Post by keeton. »
i dont have a clue then :smt017
2002 zxr400
Broken.
keeton. wrote:i dont have a clue then :smt017
What is it you don't have a clue about ? :smt017 ......................you've asked a queation and got a good accurate answer
The top mounting for the rear shock has a long threaded bit that can be used to adjust the apparent length of the shock therefore changing the ride height
