Luckily the valve didn't drop right in and act as a centre punch for the bore so just a rehone and machining to remove head damage was in order. Also decided whilst I was at it I want to give the top end completely fresh components with new pistons/rings/collets/stem seals etc all around. Here's what's its going to cost in parts:
Done countless 2t's motor builds but this is my first 4t build, looking forward to the piston's arriving from Japan and getting on with it. Once done I doubt it would've worked out much cheaper than buying a running zxr400 l3 but I'm happy to use this bike as opportunity to learn about 4t's. Also I'll be happy in the knowledge that the motor will be good for a long while, ready for my jaunt to isle of wight for august bank holiday
Just wondered as this L3 is an import will it be restricted just via the speedometer? Or by any other means?
Ta,
Jack
P.S. Any bristolian/surrounding area members?
