hello, im about to buy a new (used) L9 engine for my L9 with a knackered engine,
is it easy to switch them? how do i go about doing this?
engine change
- My Bike: Kawasaki ZXR400 L9
Re: engine change
yes
you take the old engine out of the frame and put the new/replacement one in
- My Bike: zxr 400 l3
Re: engine change
fairly easy job shouldn't take more than an afternoon if it's your first time, everything you need to know is in the manual it's all straight forward and doesn't require any special tools, you might want to check the valve clearances on your new engine whilst it's out of the frame as it'll be easier
chris
chris
- My Bike: ZXR400L1/VT750C2B/VT600
Re: engine change
and cam chain/tensioner/guidethomp1983 wrote:valve clearances on your new engine whilst it's out of the frame as it'll be easier
Re: engine change
this post viewtopic.php?f=55&t=7671&p=61071&hilit ... val#p61071 should help, it's for fully stripping an engine down but you only need to follow the bit from taking off the rocker cover to removing the chain tensioner, also use the manual on the main part of this site aswell. your looking at about £100 in parts to replace all of the timing chain parts. you'll need a set of feeler gauges to measure the valve clearances and possibly a micrometer if you need to start measuring the shims
just found another thread for you whilst looking for something else
viewtopic.php?f=55&t=8002&p=94229&hilit ... nce#p94229
chris
chris
