Header Tank
Re: Header Tank
are you sure they/you aren't getting mixed up with the thermostat? you put that in boiling water to see if it works, cos if yours is seized which judging by your old coolant could well be then it may not be opening and letting the coolant flow round the engine which is why its getting too hot.
- Wabby
- My Bike: ZXR400
Re: Header Tank
Just filled her up with water, and let her run to temp.
The fan kick in now on half temp, and keep doing so every 20 seconds or so on idle (To stop it getting too hot).
So now it doesn't seem to get too hot, and the fan seems to be keeping it cool.
I also started it with the rad cap off (Somebody said to, to see if the water ripples, or bubbles) - It ripples so apparantly that means no air is getting in anywhere that is shouldn't (eg headgasket?) is that correct?
After I had her running, I popped rad cap and she had taken about 100ml of water - But could this be it just leveling itself off? (I have retopped up and just waiting for her to cool down so I can have a look again)
Cheers for the help guys.
P.S - Where is the thermostat and how easy is it to test? Cheers
- Wabby
- My Bike: ZXR400
Re: Header Tank
OK. The heat issue is sorted
She no longer overheats.
Still pushing coolant into the header tank, and then pushing it out though - would this be just the cap?
Gonna order a new one I think. . . .
rover220
- My Bike: zx7r p6
- Wabby
- My Bike: ZXR400
Re: Header Tank
Think I may have too.rover220 wrote:quite possible its the head gasket.
can you do a compression test at all?
Just use a normal compression tester, screw into spark plug hole and compare all 4 cylinder pressure? (Have one from when I had my trusty
rover220
- My Bike: zx7r p6
Re: Header Tank
yeah, any tester with the right size thread will be fineWabby wrote:Think I may have too.rover220 wrote:quite possible its the head gasket.
Just use a normal compression tester, screw into spark plug hole and compare all 4 cylinder pressure? (Have one from when I had my trusty2 stroke. lol)
