my zxr is making me hate it!!
- carlingboy
- My Bike: kawasaki zxr 400 L1
Re: my zxr is making me hate it!!
Rob the cr9 eix iridium plugs are single contact well i hope they are as that's what i put in mine after asking bloke on ngk stand.Please please please dont tell me i put wrong ones in
There are only three kinds of people; people who can count and people who can't.
perhaps i am wrong then.........
......yup it appears i am.
My bad
My bad
WelshD1K
proper confused!!! what am i lookign for if i can fir pre heaters?? ill take pics in morning!
Davw
I'll take a pic when I get back as my engine is in bits so you can see the tapping for the water off the barrelsWelshD1K wrote:proper confused!!! what am i lookign for if i can fir pre heaters?? ill take pics in morning!
Davw
OK - these three pics should clarify it (I hope)
In effect there are three key issues
1) Does the engine have a collant nipple (pic 2)
2) Are the carbs set up for carb heating (inlet and outlet and joining hoses across the base
3) You need the hose attachement shown in pic three - this is the UK spec and has a take off in the middle for the small flex taking the coolant back from the carbs
Not sure what the inline devices are on the supply and return hoses for the collant to the acrbs but I assume some sort of NRV to prevent crossfolw from fuel to coolant (or vice versa) - or some sort of folw regulator
Davw
Apologies for the toad pic of the nipple but it is just between and below inlet 1 and 2 as you look at the engine from behind
WelshD1K
engine block thing yes got a screw in it atm that looks liek its been silaconed in :S
umm carb heater pipes ill have to checuk tomorrow as ill have to take the carbs of . thing is if my carbs aint got them dont wanna change carbs just had them cleaned and balanced
MillaMeter
The burbling and cutting out could also be condensation from the cold weather. I've just this minute finshed putting my bike back together after a routeen check. Found that my breather pipe has drops of water in it, airbox swimming in water, and 2 HT caps a tad loose.
Regards
Rich
Regards
Rich
lewisdale
- CBT slow
- My Bike: zxr400 H2
yer thats y i said give the electrics a going over with some wd40
