Does your zxr400 have hot starting problems?
Do you have hot starting problems with your zxr400?
yes
132
66%
Nope
68
34%
Total votes: 200
sic1181
Re: Does your zxr400 have hot starting problems?
Post by sic1181 »
i am guessin so he just said engine thermo, i said 'oh poo is that bad lol'
Ghost Rider Is God!
stumpy
Post by stumpy »
mines a L3. had hot start problem when i got it and it was standard but since adding some parts its been fine.
standard downpipes with race can
k+n filter
new coils and ht leads
think problem with hot start was coils?
BANJO
My Bike: ZX4R NINJA
Post by BANJO »
Standard Air filter
No idea on spark plugs but ngk plug caps
Standard carbs
Standard exhaust with scorpion end can
19847miles
Carb heaters
The bike has just started playing me up. Right when she is hot i have to hold the throttle wide open and hold the starter on for about a min then she starts and run's at about 2k rpm at full throttle for about 2min's then she jumps to life and she is ok till i cut the engine and try a restart and it's the same again when she is HOT. Starts 1st time when cold
Regards
Banjo :smt035
littleninja
Post by littleninja »
L3
standard filter
NGK cr9ek plugs
no jetting
standard exhaust, Art race can
36,000 miles
sometimes needs to be turned over for a second or two longer but no major issue, a blip of the throttle and it soon comes alive :smt001
He who dares,WINS.........
carsounds_dan
Post by carsounds_dan »
yep, had hot starting problems earlier.
tryed the crank with open throttle and he-ho it worked!!
also needed to adjust the idle speed so did that lol
not sure about carb heaters or not. ill check when i do my service next sunday
cheers
dan
...i know, it's great :D
zxr_oli
My Bike: Daytona 675
Post by zxr_oli »
'90 H2
36k ish km
stock airfilter
carbon can co. can
not sure about plugs or jetting
will start but takes about 5 secs of crank time to get going
dizzycat
Post by dizzycat »
Sounds to me like nobody really knows for sure why this happens! So frustrating for a girlie to have to ask for help to bump start! :smt010
leon
Post by leon »
ive heard its valve clearances. so lets start again by asking if ur bike does it and when valve clearances where last set
zxr_oli
Post by zxr_oli »
leon wrote:ive heard its valve clearances. so lets start again by asking if ur bike does it and when valve clearances where last set
Mine starts fine now, all valves are ok expect one that is miles to loose :(
mandie82
My Bike: ZXR 400
Post by mandie82 »
L9
Standart air filter
Titainium plugs
Beowulf stainless steele can
dyno jetted.
fine when it is lovly and warm! but when its cold.. she is a misrable cow!
mandie82 wrote:L9
Standart air filter
Titainium plugs
dyno jetted.
trust a woman to throw a spanner in the works, we've all got/had/debating hot starting problems and you have cold ones :smt017
mandie82
My Bike: ZXR 400
Post by mandie82 »
hehehheheh
Its true though... have no idea why she is like that
mike684
My Bike: GSX-R 750 ZXR400SP
Post by mike684 »
Cheers for that Rob. Sorry I've been away for a bit guys - I've been a very busy man....
My battery is fine. New before the start of the season. I called the John at Track Electronics and explained things to him. I thought it was maybe to do with the TPS as I've had bother with that before and have it disconnected completely at the moment. It turns out it's nothing to do with it. He said that as the motor turns a little and dies (as in you'd assume that the battery was knackered) when it's hot, but is fine when it's cold it is not an electrical problem. His diagnosis is that something in the engine is increasing friction when hot to such a level that the starter can't turn my engine, but that bump starting it can overcome the problem because it forces the engine to turn even if it's sticking a bit. My winter project is to 1st move house and get my new garage sorted out, then check my cooling pump as my bike took a knock just beside it in a small off and tore a cooling pipe. I'm wondering if the engine is maybe running hotter than normal as a result of this. If it's ok then I'm going to try new pistons and rings/ possibly a re-bore as well if the bores are in a mess.
The joys......
Respect it, but if you're scared of it, get off and let someone who's got balls have it instead........
nickp
Post by nickp »
H2 model
Just purchased the bike 2 weeks ago
Standard Air filter
Standard plugs i guess?
Standard carbs
Standard exhaust with some aftermarket can
17847 km
Got no problems starting the bike, hot or cold
we're neck and neck now!!! :smt017
