Loom, inbuilt fuse??
SplaTZXR400
My Bike: ZXR400
Post by SplaTZXR400 »
hi guys, iv just bought a supposedly zxr400l loom for my zxr400l model. it looks identical, excpet that theres an extra white wire which goes into a fuse to a red and green wire to the ic ignitor?? the wiring diagram for h and l models only have 3 wires on this plug so wots this 4th? cheers.
SplaTZXR400
My Bike: ZXR400
does any1 else have this wire on a ZXR400L model, it would be pretty destinctive.
what fuse is in it mate?
SplaTZXR400
My Bike: ZXR400
sorry my fault, i got it wrong, its not the cdi its the headlight relay lead n that fuse i think is for the high beam, but why is the wiring different?think the cdi is fine but the fuse box has a couple extra wires on it. onthe little plug it has bout 9 wires instead of 6 i think. its 15 A fuse by the way, comparing to the wiring diagram its the high beam fuse, but y dont it go through the fuse box, n y have i got different wires?
maybe there has been a problem with the wiring in the past and someone has bypassed the fusebox and bodged the wiring to get the headlight to work?
SplaTZXR400
My Bike: ZXR400
dunno it looks well done if so. but then why thee different wires? also on the cdi it has a separete live, instead of a brown wire which links with the ignition and everything, it has a standalone white and brown wire, which also goes to the fuse box, i counted n my loom has 5 wires on the small fuse box plug, this loom has 9.
