zxr400 fecked
deviant
Re: zxr400 fecked
Post by deviant »
buy a cycle trip computer from halfords?
Renegade
Re: zxr400 fecked
Post by Renegade »
ah ok kool, how do they work? like how do you fit them lol, never had to get one before
Re: zxr400 fecked
yeah as said get a cycle computer, unfortunately most only go upto 120mph which is no good for me, but the cycle computers mount on the bars or wherever then a magnet glues to the wheel or disc you set the computer to your rim diameter (assuming you glue the magnet on the rim) and away you go.
deviant
Re: zxr400 fecked
Post by deviant »
magnet fits onto wheel spoke
sensor cable tie's onto fork leg
display fits onto top yoke or somewhere else.
depending how much you spend, sensor and display may or may not be joined by a wire.
baz, you're wrong :smt003 . diameter you enter is the rolling dia of the tyre. doesn't matter what radius the sensor is mounted at, it just counts revolutions. the important thing is how far each revolution takes you down the road, ie the circumference of the tyre
i guess your speedo is under reading by a fair bit if you've put the rim dia in!
Re: zxr400 fecked
deviant wrote: baz, you're wrong :smt003 . diameter you enter is the rolling dia of the tyre. doesn't matter what radius the sensor is mounted at, it just counts revolutions. the important thing is how far each revolution takes you down the road, ie the circumference of the tyre
well cheers for that, i couldn't understand why i couldn't hit 185mph which i was told was the top speed when i bought it. :smt005
Renegade
Re: zxr400 fecked
Post by Renegade »
well i think it sez its only got 2 settings for the size of the tyre, and iv got 18'' rear and 21'' front, do you need indicators for an MOT? also the brake light comes on when u press the rear brake but not the front one.
also i need some fuckin street legal tyres and teh bulb for my headlight lol!!
Re: zxr400 fecked
buy another bike if i was you mate :smt003
Renegade
Re: zxr400 fecked
Post by Renegade »
nah lol i can get the tyres ok just wanteed to know what i need for MOT?
indicators?
bulb in headlight can be changed easily enough and the bike shop should be able to sort the brake light problem
deviant
Re: zxr400 fecked
Post by deviant »
look at http://www.ukmot.com for the motorcycle mot manual
don't know about indicators whether it's just if fitted they have to work, or bikes made before a certain date, or what. might be in the mot manual.
the rear light there definitely is a date, my 1978 gs400 has no switch in the lever, but one in the pedal. should be in the mot manual.
lol @ baz. but he does have a point.
Re: zxr400 fecked
indiactors have to be fitted for bikes Aug 86 and newer. i can bluff it cos i have a D reg :smt003
deviant
Re: zxr400 fecked
Post by deviant »
cool. don't need any on the gs then.
will probably fit some anyway. definitely not the gigantic stock ones though.
Northern ANdy
My Bike: Unique ZXR400
Re: zxr400 fecked
Post by Northern ANdy »
you could get a daylight MOT if you don't plan to use it at night.
You will need a brake switch though, I'd just buy a pressure activated one.
Andy
Renegade
Re: zxr400 fecked
Post by Renegade »
still need indys lol, anyone know where they sell the full road conversion kits for these? as in indys, lights maybe ignition if its possible to fit one.
brake light works but not when you press the front brake lol, only works when u press the back brake
deviant
Re: zxr400 fecked
Post by deviant »
how old is it.
pre april 86 you only need it to work on one, guess it's probably newer than that tho
Renegade
Re: zxr400 fecked
Post by Renegade »
1998
