zxr400 fecked
- deviant
- My Bike: ZXR400 L3
Re: zxr400 fecked
buy a cycle trip computer from halfords?
Renegade
Re: zxr400 fecked
ah ok kool, how do they work? like how do you fit them lol, never had to get one before
Re: zxr400 fecked
yeah as said get a cycle computer, unfortunately most only go upto 120mph which is no good for me, but the cycle computers mount on the bars or wherever then a magnet glues to the wheel or disc you set the computer to your rim diameter (assuming you glue the magnet on the rim) and away you go.
- deviant
Re: zxr400 fecked
magnet fits onto wheel spoke
sensor cable tie's onto fork leg
display fits onto top yoke or somewhere else.
depending how much you spend, sensor and display may or may not be joined by a wire.
baz, you're wrong
. diameter you enter is the rolling dia of the tyre. doesn't matter what radius the sensor is mounted at, it just counts revolutions. the important thing is how far each revolution takes you down the road, ie the circumference of the tyre
i guess your speedo is under reading by a fair bit if you've put the rim dia in!
baz, you're wrong
Re: zxr400 fecked
well cheers for that, i couldn't understand why i couldn't hit 185mph which i was told was the top speed when i bought it.deviant wrote: baz, you're wrong. diameter you enter is the rolling dia of the tyre. doesn't matter what radius the sensor is mounted at, it just counts revolutions. the important thing is how far each revolution takes you down the road, ie the circumference of the tyre
Renegade
Re: zxr400 fecked
well i think it sez its only got 2 settings for the size of the tyre, and iv got 18'' rear and 21'' front, do you need indicators for an MOT? also the brake light comes on when u press the rear brake but not the front one.
also i need some fuckin street legal tyres and teh bulb for my headlight lol!!
Re: zxr400 fecked
buy another bike if i was you mate
Renegade
Re: zxr400 fecked
nah lol i can get the tyres ok just wanteed to know what i need for MOT?
indicators?
bulb in headlight can be changed easily enough and the bike shop should be able to sort the brake light problem
indicators?
- deviant
Re: zxr400 fecked
look at http://www.ukmot.com for the motorcycle mot manual
don't know about indicators whether it's just if fitted they have to work, or bikes made before a certain date, or what. might be in the mot manual.
the rear light there definitely is a date, my 1978 gs400 has no switch in the lever, but one in the pedal. should be in the mot manual.
lol @ baz. but he does have a point.
Re: zxr400 fecked
indiactors have to be fitted for bikes Aug 86 and newer. i can bluff it cos i have a D reg
- deviant
Re: zxr400 fecked
cool. don't need any on the gs then.
will probably fit some anyway. definitely not the gigantic stock ones though.
Northern ANdy
- My Bike: Unique ZXR400
Re: zxr400 fecked
you could get a daylight MOT if you don't plan to use it at night.
You will need a brake switch though, I'd just buy a pressure activated one.
Andy
Renegade
Re: zxr400 fecked
still need indys lol, anyone know where they sell the full road conversion kits for these? as in indys, lights maybe ignition if its possible to fit one.
brake light works but not when you press the front brake lol, only works when u press the back brake
- deviant
Re: zxr400 fecked
how old is it.
pre april 86 you only need it to work on one, guess it's probably newer than that tho
Renegade
