hoover pipes
front tank cover
riders seat
petrol tank
airbox
and you should be presented with the top of the engine. Remove the HT leads noting where they go before you remove them. Then hey presto you should be able to get to the spark plugs. Make sure you have a thin walled socket as the hole to the plugs narrows the further down it goes and a standard socket piece will get stuck.
