Bleeding brakes
				zxr400@prodigy
Bleeding brakes
hi guys, have any of you stripped the calipers down and once putting them back together they will not bleed up and my brake lever is coming back to the bars, so do any of you lot no were the air maybe setting up camp and not budging.
									U wish ur car looked as good as my bike dnt u!
				zxr400@prodigy
- Jamz
 - My Bike: Kawasaki ZX9-R C2
- Xphyral
bleed off the master cylinder m8.
Stick some tissue under the banjo bolt, fill up the reservoir and then do the same as you would for the calipers. Pull in lever, undo master cylinder banjo and then retighten and release lever.
then start to do your fluid change for the calipers, it makes life a lot easier and quicker than leaving the top off the cylinder overnight.
i've had problems bleeding brakes before, if you get a big syringe with a ruber tube on then you can physical suck the fluid down the line trust me its really bloody good and they only cost about £5 well worth!
bloody good idea just search syringe on e-bay or...............
http://cgi.ebay.co.uk/syringe-kit-for-m ... dZViewItem
think thats the same kit as i got if you only use it once at that price its well worth it!
This is what i use, and you can use it for many other things too. Best thing ive ever bought
http://cgi.ebay.co.uk/Mityvac-Hydraulic ... dZViewItem
				madshady
