fuel pump goes, but not the starter motor
- My Bike: zxr 400 L8
Re: fuel pump goes, but not the starter motor
Update just had another mess about with it. found out that if i press the clutch switch in it turns over so it will only turn the engine over with the clutch left out and engaged :S
clutch switch?
yea, but isnt the bike only meant to start with the clutch pulled in ? this one seems to be the other way around
IIRC, you only need to pull the clutch in if the bike is in gear...maybe its a symptom of something else? the bike has a neutral switch by the gear sellector lever, a problem there perhaps?callum@93 wrote:yea, but isnt the bike only meant to start with the clutch pulled in ? this one seems to be the other way around
electrics aren't my thing
yea maybe, il have to get the multi meter out :/ Electrics arnt my thing either, il have to learn.
Thanks for the help !
