Streetfighter H2 Project
- My Bike: kawasaki zxr400 H2
Hello everyone, iv decided to fully strip down a H2 streetfighter that I bought at the start of summer, it wasnt in the best shape when I got it, but now winter is here im going to do a full rebuild on it
This is what im starting with
http://sphotos-e.ak.fbcdn.net/hphotos-a ... 8234_n.jpg
So far iv got it to this stage. Im waiting till friday to drop the engine because thats the soonest someone can help with it, I don't want to end up dropping it and making more work for myself!
Re: Streetfighter H2 Project
I've decided to stay indoors today as its freezing! so im going to try and overhaul the brakes, stripping callipers and cleaning etc, hopefully their not in to bad condition
The pins in the rear caliper were seized in tight! had to split the caliper to have a good go at them! sadly we had a casualty so the drill needs to be cracked out tomorrow.
In the front calipers I tried to get the pistons out, but 2 of the pistons on the same side were seized, and this happened on both sides!
update on the bike;
havnt really done much in the last 2 days due to me working, the engine is out now, only thing is that the pivot bolt in the swing arm just wont budge!! its spinning ok but just wont slide out no matter how much I swear at it! im guessing the grease has gone solid inside :smt013 im a bit stumped as what to do, ive been showing it the angry end of the hammer but still nothing, if I fully go at it it'll probably come out but at the expense of the threads and bearing inside, iv seen loads of pivot bolts for sale on ebay so I might have to go to town on mine and get myself another one. I had to get the blow torch on the suspension linkage nuts to get those buggers! I dont think my bike wants to come apart! and the rocker cover is stuck solid as well!!!!! im greasing everything to within an inch of its life when it goes back together!!!!
- My Bike: ZXR400L5
Hi. I had a similar problem with the swinging arm bolt on my L1. The thread can be found here: L1 Swinging arm (1981) - type that into the "search" box at the top right hand corner of the forum and it should lead you to it.
If you do decide to destroy the bolt (rather than the frame by continually hitting it), I may be able to fix you up with another bolt; I shall have to have a rummage in the garage (they cost £35 new!!). You may also find that the tubular spacer inside that also acts as the internal bearing surface for the needle rollers is corroded or worn. I doubt I'll have one of those simply because mine was shot so I had to buy a new one. Similarly, the bushes, needle roller bearings and dowel bolts in the bottom linkage may also require replacement. Put them all down as Christmas presents!! Tell yourself it will be worth it when you're breezing along leafy lanes next summer.
Heya, thanks for the link to your thread, just read the whole thing and there's a few things on there iv not tried yet, I'm going to go down the same route as you and cut the head off the bolt after I've worked it out a bit further and pull it through. iv just been out now to put the frame on its side and let some penetrative oil work its way through to the grease. I'll have another go at it tomorrow and let you know how it goes. Definitely sounds like I'm going to have to tweak my Christmas list!
hello again! been a while since iv done much to my bike due to the christmas period. I took my frame and swingarm to a workshop today to have the pivot bolt removed as id tried EVERYTHING I could of done at home, and guess what....even they cant remove it! the next step is going to be taking it to an engineering firm and see if they can press it out. fingers crossed!!
FINALLY GOT THE PIVOT BOLT OUT!! only took a 15 ton press...
Now that its all apart I can get on with painting the frame and swingarm. aiming to get it done by next week so will have some good pics to put up soon
mine looked like that on the fzr, took a week of hammering the thing with a rubber mallet to remove it!
Hello again everyone, sorry iv not uploaded any pictures recently, the weather here as been so bad that iv not managed to do any painting its at times like this I wish I had a garage! Iv got everything ready though so the second it gets warmer and less windy I'll be straight on it. Iv bought new swingarm pivot and head bearings, suspension linkage and pivot bolt and also a new undertray. Iv found some brake callipers both front and rear that have been professionally rebuilt, but they are from a H1 model, iv spent a few hours looking through the forum and iv not found anything about if H1 callipers fit the H2. Iv looked at the disc sizes and mounting holes and they seem to be the same, so has anyone fitted these before or know if they will fit? from what I can see in the picture they seem to look the same but I just want to check with some people who know a bit more than I do
Much appreciated. Dan
as far as i know, there are no differences between the H1 and H2 brakes.
no difference betweenthe H1 and H2, its between the H and L models theres a difference.
thank you, very much appreciated!
Hello again everyone, got some more pics of where i'm upto with the build.
The swingarm and frame have also had new bearings fitted.
