Oil Cooler Removal
- My Bike: ZXR400
Oil Cooler Removal
If i take off the oil cooler should i link the pipes together or blank off on the engine?
Common sense is telling me to keep them connected without the cooler in the circuit, if so does anyone make such a connector?
- My Bike: zxr 400 l3
Re: Oil Cooler Removal
you can remove and bypass the oil cooler using the stock lines, iirc the longer one just needs bending round to fit but it's fairly obvious once you get down there and look
chris
chris
pretty sure you can just blank them off too.
- My Bike: ZXR400L5
I decided to take the safe option to ensure that oil flowed without any restrictions. I used a piece of 10mm central heating pipe with elbows and a couple of scrap pieces of brass. Oh - and a couple of gaskets cut out of a Cornflakes box.
- R P Corse
- CBT slow
- My Bike: ZXR400 H1
thats pretty cool that!
though im still unsure on the benefits of losing the oil cooler - apart from losing the weight
MotoGP bikes have oil coolers on
someone needs to stick a couple of thermocouples around their bike, sling it round a track with/without oil cooler, then around town with/without.
- My Bike: zxr 400l sp
In fairness the gp bikes have huuge fire breathing engines in em and cooling is an art! Yea weight loss thats it!- Its a racing mod imo!BigB wrote:thats pretty cool that!
- R P Corse
- CBT slow
lol oh i agree bout the GP engines are fire breathers lolrccaulfield wrote:In fairness the gp bikes have huuge fire breathing engines in em and cooling is an art! Yea weight loss thats it!- Its a racing mod imo!BigB wrote:thats pretty cool that!
i mean i've seen lots of people have pros and cons about removing the cooler, as much as i'd like to try it out, im scared as to how hot the bike would be
- My Bike: zxr400 L racebike/R1
removed my oil cooler on my racebike, just made a blanking plate up that covers both holes and fits onto all 4 boltholes. If engine cooks itsself i will report back and let you know
zxr400L Race Bikes Competing in EDIASIA F400 and thunderbikes with BMCRC in 2016 and an RD125LC MK1 restoration project
My bike still has the oil cooler on it but the new build will see it removed. It runs at the right temp when it's almost 100 degrees F outside without any tape on the radiator. That would be just over 37 C for the metric crowd.
Mine doesn't run on the street, only the track.
- My Bike: many
Hi Guys removing the oil cooler is perfectly fine and you can simply blank the cooler outlet and inlet feeds, no need to have a bypass system like the one in the photo as in practise only some of the oil from the pump goes through the cooler anyway. I have blanked mine but I have fitted a cooler from a ZX6r which fits where the oil filter is and is water cooled.
Hope this helps steve
- My Bike: ZXR 400 L2
Hi Stevi5
Do you have a picture of the Zx6r system?
Regards
Thierry
Regards
Thierry
forum français : http://zxr400fr.bestthread.com/index.php
- My Bike: many
Yep but not sure how to post it on here, if you let me have an e-mail address I will mail them to you direct.
regards stevi
regards stevi
Blanked off my oil cooler as I found a cracked line while prepping my bike a few days before my last race. Still had to tape the radiator to keep it in the right temp range. Cut them with an angle grinder, used the lines as a template for drilling the holes, no issues, no leaks and I got a third after not racing for over a year.
Hello.
Do you think that after removal oil cooler , the seal valves can be damaged (oil too hot) ?
Titi
Titi
