get the tail unit, then i can build the rear subframe and tail tidy. i will also make a one-off rear brake caliper holder, might try to copy the R1 where its a bar welded to the inside of the swingarm, or whether i will just get a small torsion arm made and mount it under the swingarm...im still undecided on a small rear hugger or not.
then its sorting out the rear shock (might go with a racing-type on with the compression on a thing that sits above the shock...you know what i mean), but if so i will need to mount the battery somewhere different...wanted to put it above the shock to mass-centralize a bit...will have to see if i can learn something like autocad and have a play about?
then i can get the rear electrics and all the relays/EXUP servo/CDI etc. relocated under the seat, again, want to get these just about under my butt, to get them forward.
its getting to the stage where i need to spend money now
