I have a L5 which has been running a bit rough, revs kept playing up and it used to bog out on me a lot, especially from a stand still.
I went to a garage and they had a look and cleaned & setup my carbs, now it works a lot better but still not perfect, they said it will still run a bit funny sometimes (revs hang up for a bit when coming to a stop) and when going at a constant speed then pulling the throttle a bit, it
They said this is because the bike is old and the carbs get worn overtime, and that i could try a different set of carbs eventually. Now my thought was, when i had my airbox off at one point and started the bike, i saw the diaphragm slides vibrating up and down on idle, and when revving slightly they would be a bit glitchy.
Is this normal? or should they be dead still on idle, and moving up and down smooth when revving?
If its not normal then i think replacing my diaphragm rubbers might solve my issue, but want your opinions first before i spend money
Thank you!
