New to the forum, I have a H2, that I can not get to start, heard the bike running when i swapped it for 2
.. i have 12v + at both coil packs both wires, the pick is giving the correct resistance reading.In desperation I have opened up the fuse box, diodes are good ... but the relay smells burnt, but i am unsure if this a head light or starter relay, (though headlights work fine )behind the battery is another relay (not indicator or fuel pump) which has no markings on it
Could some body link me to a H2 wiring diagram or does thoughts with what the issue could be
Thanks in advance Mark
