ok so my rocker cover gasket is leaking slightly.
if i get some gasket sealant or silicone, is it just a matter of removing the top 4/8 bolts, taking the rocker cover off and sealing the whole cover with sealant?
also ive got another oil leak from a pipe that goes from what looks like the rocker cover down past the coolant tank, and passes where the cable guide for the clutch is? any idea what it is?
i will get some pictures later
rocker cover gasket
- BigNinjaDave
- My Bike: ZXR636, ZXR400
so the rubber o ring is at the top of the pipe, because the oil is leaking at the top then running down the pipe. is it just a matter of undoing the allen key bolt, taking the pipe off, replacing the o ring then just putting it all back together?
and does anyone know where i can get the rocker cover gasket?
yes just take the allen bolt out and replace the o ring you may get a little oil coming out when you take it apart but not much. Make sure you do not overtighten itmuffinman wrote:so the rubber o ring is at the top of the pipe, because the oil is leaking at the top then running down the pipe. is it just a matter of undoing the allen key bolt, taking the pipe off, replacing the o ring then just putting it all back together?
For all zxr400 parts try http://www.cradleykawasaki.co.uk/
